Located in Anacortes. Does anyone have a suggested vendor near Anacortes to replace our smoked plexi door that leads up to upper steering station. Suggestions of folks to suggest, or better yet, ones to AVOID! Thanks
4788 Pilot house to upper steer station door replacement suggestion-gctid828462
You're just wanting to replace the Perspex correct?? It's tinted and I think 1/2" thickness. Any plastics supply company (maybe Tap Plastics) can cut you a new one using the old one as a pattern. Shouldn't be hard to remove the hinge/bracket screws to pull the door off. Google, call them and compare pricing and bobs your uncle!! :whistle:
Cheers
John H
Brisbane QLD Aust
"Harbor-nating"
2000 - 4788/Cummins 370's
