antifreeze for 150 hino/ flush out ?-gctid827984
    Pcpete
    Supporting Member
  • Pcpete
    I have the six cylinder 175's but much of it should be similar. There is a drain at the bottom of the manicooler and on the port side of the block near and a bit behind the starter. I opened them up and ran a hose to the radiator cap port. To flush the hot water tank and heater, I unclamped a hose at the engine and flushed them the same way. When it came time to refill, I refilled the heater and heater via the hoses until I saw coolant coming out of the block drain, reconnected the hoses then finished through the cap. I used the Peterbilt certified coolant from NAPA as recommended by Earl. It was a bit of a challenge to find until I found a NAPA store next to a truck shop. My other option was to order it by the case from any store.
  • EAGLE_III
    Frequent Contributor
  • EAGLE_III
    started a topic antifreeze for 150 hino/ flush out ?-gctid827984
    There is a good article on 32xx web site on how to change the antifreeze on a 150 hino. I would like to flush out my engines also and would like to know if you cut in a flush out "T" and where do you install it or is there another way?
