120V burner elements on Princess Stove.-gctid827889
    About two years ago I replaced all three of the crusty ill-heating burner elements on my Princess stove top with the same elements that the previous owner had installed. I bought them at Lowes and they were cheap. Then I listened to my wife complain four the past year that they took for ever to heat. Following the last expression of dissatisfaction, I noted that the elements I had installed were actually 220V 1150 watts. So I ordered two 120V 1100 watt elements and a 120v 550 watt for the rear burner and installed a few days ago. WOW! now they heat instantly and actually glow! $23.00 each but a great expenditure.
    Looks like you found a cure for the notoriously slow 110 vac Princess stove top. Thanks for sharing.
    Greg
    Newport, Oregon
    South Beach Marina
      Where did you order them from?
        I don't think it's a cure for slow 110v burners. It's a cure for trouble shooting why 220v household burners don't work as replacements. Sure Marine has replacements.
