PLEASE HELP SUPPORT OUR SITE
I am unable to get the attached snubber to work consistently. I set it up per instructions and it falls out in the middle of the night. I'm typically anchoring in 10-20' of water with a 5:1 scope. I set it up so the "loop" hangs what seems appropriate and it seems to fit the chain. 30 mph wind or no wind same results. What am I doing wrong?
What do you all use for snubbers?
MV Kia Orana
Currently Enjoying the PNW
Feed me drinks and I'll come over and show you how to set with a proper snubber. Damned noobs
Are you expecting a big blow with 5 to 1 scope, assuming an all chain rode, that seems excessive to me unless you have a light wimpy anchor.
Started boating 1965
Not expecting a big blow but some of the anchorages are an open rodestead which are fairly uncrowded. There are also 180* reversing currents and the 5:1 seems to reset well. The holding ground is great here in the SF Bay. I've got a 80# Manson Supreme and all chain G4 5/16" rode. Our tidal range is about 6-8 feet.
So I pull into an anchorage with a charted 10' mlw depth. My depth sounder says 14' I figure I'm at about mid tide. If I add about 5' for the bow off the water, I put out about 80' then rig up my snubber and let out another 15-20' so my total rode is about 100. I don't see why this should be a problem with the snubber staying engaged? I've anchored with a similar setup on sailboats in the Caribbean and Bahamas maybe 50x no problem. I've only anchored our boat maybe 25x and the snubber becomes unengaged. What am I missing?
MV Kia Orana
I've had good luck with a standard chain hook and a length of 5/8" line. It has never come loose. As you can see from the photo I have it set up to grab the chain slightly underwater. This provides a more horizontal pull on the chain and allows for a bit less scope. I also let out enough chain so it is loose between the anchor roller and the snubber hook. This way the load is carried by the snubber. A side benefit is that there's no noise from the chain on the roller transmitted to the boat.
2013 Boston Whaler 130 SS
Isla Verde, PR
So, is you snubber legs 15-20' long each? Am I understanding this correct? If so, at low tide, and when the tide reverses, you snubber chain grabber may be resting on the bottom and this is when the grabber releases from the chain link. This is all I can think of that would cause the chain grabber to come free. Do you have the same problem anchoring in deeper water?
I use the same set -up you have,however I stop my chain hook just above the water and if the chain finds a rock I hear about it, so if I lower it deeper into the water I wont?? Thanks Brad
A little help here from one who has been barred from anchoring for years. Something about cold water showers on the previous boat.
In looking at the pictures the snubbers appear to be more for lowering the angle of the dangle than as a shock reliever. Am I looking at that correctly?
Edmonds Yacht Club (Commodore 1993) 1988 3818 "GLAUBEN”
It's both. I've been anchored in gusty wind and waves and watched the snubber lines (3-strand 5/8" nylon) stretch and contract. If I had not had a snubber the jerk on the chain would have been stronger and higher up.
Isla Verde, PR
. If I had not had a snubber the jerk on the chain would have been stronger and higher up.[/quote]
How tall and muscular is this 'jerk' on the chain? :P
Greg
Newport, Oregon
South Beach Marina
