For years it has bugged me that my tachos have always read differently between the engines.
I've replaced 2 of them, swapped them all around, cleaned up the contacts, even spent $600-00 on getting the whole lot calibrated.
They would read fine up to about 2400 rpm, than as more throttle was applied the port one would start to lag behind.
At 2500 it would be 50 behind, at 2700 it would be150 behind and at WOT it would be 200 behind.
But just recently.....
I replaced my fuel tanks, and guess what....
Both engines now read identical revs right across the range!
So after trying to get my head around why I should suddenly be so fortunate.... my conclusion is, that the port engine was starving for fuel at higher revs due to a partially clogged fuel pick up... how simple!
So for those with tacho's reading similar to mine.... your engines might be trying to tell you something.
I hope this helps.
I hope this helps.
