It is time to upgrade the electronics on my 3888. I am looking to replace the radar, navigation system, and depth gauge. Finding unbiased reviews of the new electronics has proven difficult; therefore I thought I would ask what others have selected and how happy they are with their electronics. Most of my boating is done on the Mississippi river; thus, I do not need a long range radar and I need a navigation system that can be loaded with the river charts. Also, to save costs, I was planning to use a tablet to monitor the radar and navigation at the second station, which requires wifi capable electronics.
New Electronics-gctid827232
I retrofitted Omega with an Garmin electronics package and love every part.
I chose Garmin for many reasons including price and options. Like Simeon said, there is a thread that he has that myself and others commented on that may help. The Garmin systems have wifi and make it so you can interface easily with tablets and such.
~BJ
OMEGA
5788
BJ
OMEGA
5788
[ul]
[li]Raytheon's system requires the MFD act as the WiFi hotspot, and the tablet connects to the MFD. This means your tablet can act as a second station, or have WiFi Internet access. It can't do both simultaneously. I inquired about adding this capability in the future, and Raytheon actually responded (their forum reps seemed most responsive and knowledgeable of the three), but it was a "we will take your suggestion under advisement, but no you can't do that with our stuff right now" response.[/li]
[li]I didn't get around to determining if this was possible with Garmin. Their screen mirroring works with both iOS and Android, but their chartplotter app is iOS-only. That led to some further research, and it turns out a lot of their software is iOS-only, which took them out of the running for me. A Garmin owner will have to say if this is possible.[/li]
[li]I was able to determine that Navico's screen mirroring works whether you use the MFD as the hotspot, or connect the MFD and tablet to the same external hotspot. So I can connect both the tablet and MFD to my phone's hotspot. The tablet can mirror the MFD screen, and will still have Internet access. So if, say, I get an email or video call, I can still access it on my tablet instead of being forced to do it with my phone. This turned out to be important last fishing trip when we were catching rockfish, and I needed to do Google image searches for pics of different rockfish species to make sure what we were keeping was legal. When done, I simply switched back to the mirroring app, instead of having to first change WiFi hotspots.[/li]
[/ul]
I ended up going with Navico for this reason. From what I could tell, the underlying software for B&G, Simrad, and Lowrance is the same. Just slight differences in presentation. Most of the difference was hardware. Lowrance was more cheaply built (plastic frame, vs metal for B&G and Simrad), and the knobs/buttons are different. B&G is aimed more for sailing. Simrad supposedly more for offshore, Lowrance more for freshwater fishermen. I got a 9" Lowrance MFD with the idea that plastic was OK because it'd be in the cabin helm, and I'd use the tablet on the flybridge. But after using it for a bit, I think I should've gone the other way. A Simrad for the flybridge, and the tablet in the cabin. These MFDs can get super-bright for use in sunlight. Much brighter than my tablet can get. And the tablet is sometimes hard to see while on the flybridge.
Do be aware that the tablet can only mirror the MFD display. You cannot have the MFD showing (say) the chart/radar screen, while the tablet displays the sonar screen. So the tablet mirroring can save you money when it comes to a second station (flybridge), but not if you want multiple screens at a single station. (In theory it should be possible to make the tablet display a different screen - newer MFDs use multi-core processors which are powerful enough to simultaneously generate multiple displays. And I know the Raytheon stuff runs Linux with X-Window under the hood, which has supported virtual desktops for decades. But I don't see any manufacturer supporting this capability when they can sell you a $x,999 MFD instead.)
The way the mirroring works is the MFD converts the screen it's showing into a streamed video (all graphics hardware has had the capability to do this in real-time for about the last 5 years). It then transmits that stream to the tablet. From the tablet's perspective, it's just playing a streamed movie. This does mean however that if your MFD's and tablet's aspect ratio don't match, you're going to get some black bars. In particular, the Navico mirroring app adds some command menus above the mirrored screen (to make up for the buttons on the MFD). My tablet happens to be 16:10 while my MFD is 16:9 (most 7" and 9" MFDs are), so the black bars are minimal. But if I'd gotten a 16:10 MFD (typical 12" and 16" MFD), i suspect the mirrored display would've been shrunk to make room for the menu at top, meaning black bars on the left and right. Likewise, a 4:3 tablet (iPad) with 16:9 MFD would mean much bigger black bars on top and bottom.
"Solandri" post=827458 wrote:
Oops, yeah. Worked in aerospace when I was younger. Raytheon sold Raymarine to FLIR a few years back (yes, the thermal imaging guys).
Greg
Newport, Oregon
South Beach Marina
