cabinet refacing and countertops
    I just recently purchased a 2000 5288 and would like to refresh cabinetry and countertops in the galley and main salon without tearing out and completely replacing old stuff. Galley cabinets are the same white laminate used in many other Bayliner models over the years. The rest of cabinet exteriors the are the teak veneer looking material. Not sure what material is used on face of teak cabinets? Some of the cabinetry has faded due to sun damage, Any suggestions on refacing or replacing the white cabinet doors and teak like material on other surfaces? Also, would like to replace countertops with either quartz or corian. Are their pros and cons to using either in a boat? Thanks, Mike
    As you know the countertop is going to be the easy part. Chose your material and your installation contractor.
    Like you I am not all that fond of the white cabinets in the later model Bayliners, prefering the earlier all teak interiors.
    Cabinets are built as a plywood box.
    On the front there is a "face frame" which is what you see in all areas the doors do not cover. This face frame is removable.
    You can have a new one made out of teak, along with doors that match .
    The problem is finding someone with the skills to do the work. Custom land based cabinetmakers have the skills but they are a dying breed. The best place might be a full servicve shipyard that has a full woodshop and a cabinetmaker on the premises.
      Look for BJ with Omega to reply or send him a PM I have been on his 57 and he recovered all his cabinetry with a Beinner that sticks on. Sounds cheap And though it might not work but it looks great though.
      5788 Man 610's- Love Her !
        I too have wrapped all my interior wood with a film. It's a lot of work but the results really modernize the boat! Either way it's a lot of work if you're going to sand/stain or wrap. If you wrap make sure you very clearly understand how to do it as it's not as easy as you'd think.
        Derek
        1989 Bayliner 3888 175 Hino’s - Mahal
        (Past)1997 Bayliner 2588 Cierra 7.4 Bravo 1 - Mahal
          A few years ago I had 2 doors on my boat replaced. The laminate material had peeled off from exposure to the sun/moisture. I found these guys: http://venlam.com/ -- if you send them the exact measurements of your existing doors, they can make you replacements in any colour, size, finish etc and ship them to you. I choose to use the existing door hardware but you could use new as well. In my case, I wanted to match the existing cabinet door colours and used their colour chart on their website. The doors were so close it was almost impossible to tell they had been replaced.
          Replacement of 2 new doors including shipping cost me $160.
          Terry
            Corian is widely used on boats because of its slightly lighter weight. However, it is no where near as durable as granite or quartz. http://www.countertopspecialty.com/c...rtop Specialty wrote an excellent article on the benefits and issues with all three, dispelling many of the myths.
            Personally, I've never been a fan of Corian because it always looks like what it is; it looks cheap. It can also be scratched and will dent of something heavy gets dropped on it. And try as they have, it will never replace the look of stone.
            That said, any of them will work, but quartz and granite would be my preference on a boat that size.
            As to the doors and fronts, being a furniture builder, what you are asking has more to do with what you want it to look like. There are some nice vinyl stick-ons, but again, nothing looks as nice as the real thing. I would ask a local cabinet shop to drop over and quote you on new fronts. Since they wouldn't be building the entire cabinet, and they won't have to redesign your galley, replacing the fronts is actually quite reasonable. Just remember, when it comes to teak, that the biggest cost is the material and the finishing.
            MMSI: 367637220
            HAM: KE7TTR
            TDI tech diver
            Kevin
              This company makes custom counter top caps that are bonded over the existing counter top. On a boat they will cut down, or remove the raised edge before bonding the cap on. I've seen their work at a house and it looked nice:
              http://www.granitetransformations.com/products/
              [img ]http://granite.garytietjen.com/wp-content/uploads/2015/06/granitegranite.png[/img]
              2013 Boston Whaler 130 SS
              Isla Verde, PR
                There are also do it yourself pour on countertop finishes. A friend did their kitchen countertops, looked great. But i don't know about UV durability in marine use. Something you might want to look into.
                1986 Bayliner Contessa 2850
                In over my head for sure!!
                M/V SKUA refit
                  Hi Mike,
                  I redid my cabinets throughout the boat. I did a combination of wrapping and staining the cabinetry. Below are a few pictures of the cabinets... like Derik said, it is a lot of work, but the results are beyond worth it. It modernizes the boat and makes really nice, it isn't too expensive if you use your own sweat equity. The price jumps if you hire someone to do it for you, I'm sure, I did my own work,,, when I did the upgrade, I also changed some of the cabinetry so it worked better for my needs.
                  I hope this helps... If you have any questions, let me know.
                  BJ
                  OMEGA
                  5788
                  BJ
                  OMEGA
                  5788
                    "igiftmon" post=827392 wrote:
                    Hi Mike,
                    BJ
                    OMEGA
                    5788
                    Nice work, BJ. This could be a new career. $$$!
                    MMSI: 367637220
                    HAM: KE7TTR
                    TDI tech diver
                    Kevin
                      Thanks BJ, The cabinets look great as does your entire interior. Did you replace your countertops too? Where is Omega moored? We are moored at Tacoma Yacht Cub. I would really like to visit with you by phone or email to get more information. What is best way to make contact? Thanks, Mike
                        Hi Mike,
                        I'm pretty close to you over in north Tacoma. I'd be happy to chat, email or meet you sometime and help any any I can. Send me an email or PM me and we'll figure a way to make it happen...
                        Talk to you soon,
                        ~BJ
                        BJ
                        OMEGA
                        5788
                          BJ, your boat's interior is absolutely fantastic! Nice work.
                          Thanks for sharing the photos.
                          Greg
                          Newport, Oregon
                          South Beach Marina
                            Thank you for your kind words,,..
                            BJ
                            OMEGA
                            5788
                              I am not able to see the pictures that Mike posted. We just bought a 1999 5288 bayliner and am interested in replacing the white with the teak cabinets and also removing the oven and converting to a cabinet. We'll be at Tyee Marina. If anyone has suggestions of someone in the area that does this that would be appreciated.
                              Jacqueline Z
                              Cassiopeia
                              1999 Bayliner 5288
