About what type of fuel usage would one expect from a 3888? I think they are 175 or 200 HP Hinos TIA
3888 fuel usage?-gctid827135
For planning purposes, I use eight gallons an hour. That's with a lot of lower speed operating, ten knots and under but also about 20% at 2800. The last 50 hours actual average was six point five per hour.
- Likes 1
I always figured these ranges in neutral seas:
3 nmpg at 6 knots
2 nmpg at 8 knots
1.2 nmpg at 14-15 knots
Seemed we always did a but better than those targets in the long run. This would assume a clean bottom, correct and tuned props, and engines in tune.
We had the 175 Hino 6 cylinder naturals in our 1986 38.
What is a "200 HP Hinos TIA" engine as described?
With the 210 hp Hinos in my 3888, I burn about 6 gph in fresh water. The majority of the time is at hull speed with about 10% at 2700 rpm. During long runs at 2700+ I average just over 1 mile/gallon; however, it is hard to calculate accurately because I am on a river and going with and against current.
