Hino 150 engine alarm-gctid399907
    Where's the sensor for the overheat temp. alarm on a hino 150? Mine seems to be stuck on.
    Front, starboard side of engine, up high above the alternator. Here's a photo. NAPA sells a 3/8 ths drive socket socket #3923 (which is a 1-1/16" socket) which may help given the tight quarters, but you'll need to confirm fit. It fits the oil pressure switch, and these look the same size. Good luck, Dean
