1989 3288 replacement refrigerator-gctid399889
    I recently purchaced a replacement refrigerator for my 1989 3288. I was told that a Norcold model DE0041R would be the direct replacement...Well thats just not true. tThe problem is the condenser and fan assembly are located on the left rear, as you're looking at the unit. This is causing the unit to hit the back bulkhead and thus not going all the way in. If that assembly were located on the right side it would be no problem. I sure could use some advise on this. Also I am new to this site so if I am not doing this correctly I apologize in advance
    Our refrig has been replaced also,, and they added a one inch piece of poplar wood on the left side next to the step. It was stained to match the surrounding wood and actually... I didnt even notice it till we had the boat a few months...
