Hey all, just found this place while looking for information on this.
Hoping one of you could give me some advice.
Im currently living (and constantly working on) an '87 bayliner 3270, and im having some serious problems with the electrical system,
specifically the house batteries. If I have too many lights on at any point, or run the pump with too many lights on, the whole system will drain the batteries and cut out, sometimes leaving me to juggle around the switches and figure out which light was left on, wait for it to recharge enough to turn on again and then have it happen all over again, its driving me mad. :angry:
The attached pictures show the current setup, which is awful. Im trying to make it work while I save to upgrade the charger to an inline pronautic 1230p 30 amp and two optima batteries to fix this up so i can have constant power again.
https://imgur.com/a/i3p10
What are you all using for your current house battery setup? Would you recommend what Im planning on upgrading to? Is there something obvious Im doing wrong here?
Thanks for any advice youre able to give.
