I would like to know how one goes about filling a horizontal propane tank on a 3388-Baylliner. The tank is located on the flying bridge. Are there any pictures of this proces?
How to fill a horizontal propane tank on the flying bridge for a 3388-Bayliner-gctid826140
You have to take it off the boat to get it filled. Any fill station near a Marina should be familiar with the larger tanks for filling.
2019 Cobia 240 CC
2006 Boston Whaler 13 Sport
1985 3270/Hino 135s (Sold)
Vero Beach, Fl.
Yes, I took mine to a fill station that was near my marina and they said "no" because it was not recognized by DOT (land based). Proceeded to take it to a RV dealer that was just up the street not too far and they filled it without a problem. It may be hit and miss but keep trying!
Keith
1986 3270, twin 110 Hinos
Olympia, WA
Not sure where you live (US vs Canada) however, see this thread I started a while back. Depending upon the tank and where you're located you might have a problem getting it filled. The thread has the current rules and regs:
http://www.baylinerownersclub.org/in...y?limitstart=0
Terry
I've been taking my horizontal tanks to Viper Fuels in Chemainus for years. They tell me they do not need to be re certified.
They are a big operation and have been around for years. Look them up. Give them a call.
Maple Bay Yacht Club
1990 3288 "Allure" w/150 hino x 2
2004 Campion 622 fish killing machine "Knucklebuster", 150 yammy 4 stroke
I retired from one of the 3 major US retail propane distribution companies a little over a year ago after 38 years in the business. Propane containers are built following one of two regulatory codes: ASME (American Society of Mechanical Engineers) or DOT (Department of Transportation). Most but not all portable containers ( i.e. "cylinders") are manufactured according to DOT regs. Similarly the vast majority (but not all) stationary containers ("tanks") such as those seen at homes and businesses are constructed to ASME standards. Among other things, DOT containers require an OPD ( Overfill Protection Device) and must be recertified 12 years from the date of manufacture and periodically after that. There are a few different methods of recertification (visual, hydrostatic, water jacket) and the method used determines the period it is good for. The easiest, cheapest and most cost effective method is visual which is good for 5 years.
All typical vertical propane cylinders are built to DOT specs and therefore fall under recertification requirements. Horizontal portable cylinders can be built under either regulation. The easiest way to determine which rules apply is to look at the specs on the data plate (cylinder stamps/markings). If there is a "cloverleaf" stamp it is an ASME container and is not subject to formal periodic inspection and marking. If no cloverleaf exists there will be a marking such as "4B240", "4BA240", "4E240" ( there are other similar designations) and you're looking at a DOT cylinder. "DOT" should also be plainly visible in the markings.
My 1996 4087 has a horizontal 10# (roughly 2 gallon) ASME container that is mounted in the fiberglass locker located on the aft deck.
Hope this is helpful.
Why Naut
1996 Bayliner 4087
Twin Cummins 250 HP 6BTA5.9 M2
MMSI 338311223
I'll be filling my propane tank in the near future. Anyone know of a station near Gig Harbor that would handle the same style of tank?
"Scandia Lady"
1990 Bayliner 3288. Twin 135 Hinos.
Westshore Marina
Gig Harbor, WA
*1975 Glasply
135 Evinrude E-Tec mounted on an Armstrong Engine mount.
Greater Puget Sound
*1992 Ski Nautique
351 Ford
Lake Tapps, WA
Why Naut
1996 Bayliner 4087
MMSI 338311223
In my search I noted the 3788 has propane stove. Don't you worry about propane gas leaking and filling the bilges? Even gasoline powered boats cause me concern, hence my search for only diesel powered boats. I have had motorhomes over the last 40 years so have some experience with propane in vehicles, but in a boat. I don't know.
Why Naut
1996 Bayliner 4087
MMSI 338311223
