New to us 3587, adding a generator-gctid826057
This is one of the down falls of the 3587. There is really no space to put it in that would allow ease of access for maintenance. The cost would be extremely high.
We have used a Honda 2000 and have been very pleased with it. It's a fraction of the cost of the installation of a permanent genny and does the job really well for us. We tie it off on the swim grid and have never had a complaint for noise as it just hums away to charge the batteries.
I have heard where some have a swim step extension and have placed a generator in the extension itself. This would be an expensive modification and would likely put you in a close price range of the 4087 who likely already has a generator installed.
The great lakes have cool water, why not use a pump and a "fin-fan" like a radiator with a fan to pump water through the radiator and a fan to push the air?
I knew a person in Racine IL. that had a deep well that did just that for his home?
I have a 96 4087 with propane. I use a Honda 2000, it will heat water in about 30 min 11 gal tank. It will charge both inverter & house batteries from 12v back up to nearly 14v in 1.5 ti 2 hours. I keep Honda in dunage box. It's quiet & very fuel efficient. It would be nice if I could do hot water & both chargers at once, but it's not quite big enough.
1996 4087 Lazy Days
2011 Porsche Cayman
2010 Lexus IS 250C
2008 Honda Ridgeline
Definitely possible to add, but the only realistic place to locate is between the engines which makes already tight access to the engines for maintenance really, really tight. Unless you know a really tiny mechanic, not sure I'd want to go there.
