Access to replace AC showerpower outlets in a 3688-gctid825999
    Hello, I have a 3688 and have lost the power to line 1, in trying to replace the plugs there is no way to get to the back of the plugs from the inside of the boat, do you have any recommendations on how to access the back of the plugs? looks like pulling the DC panel is not sufficient to reach the back of the plugs
    If your boat is like my old 4588, the back of the AC shore plugs were accessed through the back wall behind the AC panel. Tthough it was not appear at at first, as you couldn't see them after removing the AC panel, there was a fairly large wall cover that had to be removed on the panel's back wall. After you removed that cover, the rear of the shore plugs were right there and fairly easily accessed.
    I hope this helps,
    BJ
    OMEGA
    5788
    BJ
    OMEGA
    5788
      On my 3788 they are accessed by removing the ice maker. 3688 might be different.
      2019 Cobia 240 CC
      2006 Boston Whaler 13 Sport
      1985 3270/Hino 135s (Sold)
      Vero Beach, Fl.
