I'm going to move an engine start battery to the port side to better balance the boat. It might involve a slightly longer run. Is there any marine magic in a 2/0 battery cable or can I use a generic/automotive cable? Thx
Battery cable question-gctid825853
Totally agree with Wild Blue Yonder! In addition, non tinned wire sucks up water into the wire braid itself and causes corrosion. I replaced a bunch of wire and connections due to this capillary corrosion. Some of it was factory and some was by prior owners. I fixed the obvious problems. Now I just make the upgrades anytime there is a problem or I modify a system needing new runs or connections. I also recommend using closed terminal ends and heat shrinking with marine heat shrink. It has a glue that melts and seals out moisture. 12 volts is not a lot and voltage drop due to resistance from corrosion is not a good thing.
MV Kia Orana
Currently Enjoying the PNW
"Wild Blue Yonder" post=825856 wrote:
Marine wire is "tinned" and will not corrode. Do not jeapordise you insurance coverage by using non marine or ABCY or coast guard approved wire. A couple of bucks is not worth it.
Jim
Started boating 1965
Jim
Jim
Marine type tinned copper wire will corrode more slowly than bare copper wire. Since most everything deteriorates, the idea is to use materials that deteriorate more slowly. There is a point at which cost can become a factor. For example, gilded copper wire will corrode more slowly than tinned copper wire. Does one get enough extra life to justify the extra cost of the gold? Probably not. However, in my opinion one should use products and materials that are rated for marine use in a boat. That means that the regulating bodies (USCG, ABYC, etc.) approve of their use in the intended application. Has there been an insurance denial because of using the wrong kind of wire? I personally don't know the answer to that question. Have there been losses due to fire because of using the wrong type of wire? My marine electrician friend who has investigated boat fires says, "yes". It is fuel for a law suit if nothing else, and who wants that, especially if it were a wrongful death law suit. Just some food for thought.
Greg
Newport, Oregon
South Beach Marina
The marine battery cable that is tinned, and made of many smaller gauge wires and is there for more flexible as well. Just replace all our battery cables as the 27 year copper ones had served that life the resistance and stiffness made them tough to work with and effected starting and my inverter.
Mark
USCG OUPV
1990 4588
Carlsbad, CA
I have used nothing but outdoor welding cable to wire my boat batteries over the years. I always buy it used. Contractors have to start most new jobs with new welding cables. For the same outside diameter you get about double the current capacity.
I have all marine ABYC wire on my 3870, with-out exception since I rewired it in the late 90's.
I can cut any of the battery cable adhesive heat shrink off the battery cables and they will look like new.
I use only adhesive heat shrink on all electrical wires and heavy duty adhesive heat shrink on battery cables.
I works.
The cheap stuff will not prevent corrosion!
Greg
Newport, Oregon
South Beach Marina
Jim
Be safe!
[email protected]
[email protected]
Marine tinned wire is widely available on ebay at a heavy discount.
Ancor cable and wire is available.
The vast majority of wire on my 3870 is Ancor and I use heavy duty adhesive heat shrink on battery cables as well as adhesive heat shrink terminals on all smaller wire.
I can buy 100 ft of 2/0 ANCOR battery cable for $217.00, this is an example, no-one needs 100 ft unless you run cables to the forward v-berth storage.
I find great buys on Ancor or an approved Marine battery cable or wire on ebay, cheap enough that I make money re-selling it on ebay.
