Hurth 360a-gctid825729
    Port Hurth HBW 360a transmission slipping at or just above 3800 rpm. Engine begins to race. Repairable, rebuildable or call the undertaker?
    Dan
    Frostbite Falls, Minnesota
    Claudia V. III
    1988 - 3218
    Gas Drives
    Sounds like a rebuild situation if parts available. ZF took over Hurth many years ago. My boat has a Hurth 630A on one side and ZF 63A on the other due to a complete replacement. Whatever you do (replace or rebuild) - change out your Damper plate with new.
    MY 3988
    M/V MMPOWRD
    Poulsbo, WA
      I was told by a 3870 owner that the common failure is the forward thrust bearing. For this reason many owners remove both transmissions and switch them from side to side. This puts the forward load on the other thrust bearing. Before doing this I would verify if this is accurate with a trans mechanic.
      Gibraltar, Mi.
      1986- 3870- Hino 175's
      1988 26' Shamrock/ Diesel
      14' Zodiac Bay Runner
        Don't let it slip too much because the plates warp and then the transmission will not come out of gear.
        Harbor Marine in Everett WA is an excellent rebuild source for the NW,
        1997 4788 with Cummins 5.9 (315 hp)
        12 ft Rendova with 40 hp Merc 4 cycle
        Pacific NW
          Get fixed soon. Like above running too long will damage parts that are no longer available.
          2019 Cobia 240 CC
          2006 Boston Whaler 13 Sport
          1985 3270/Hino 135s (Sold)
          Vero Beach, Fl.
            Thanks guys,
            I got in touch with someone at Harbor Marine a few days back .
            Dan
            Claudia V. III
            1988 - 3218
            Gas Drives
