2002 3988 Battery Set Up-gctid825723
    Hi folks,
    2002 3988 twin 330's. House battery is port side, fwd of the fuel tank. Does anyone know which alternator should be charging this battery? Should there not be a negative wire coming off of one of the generators?
    J
    Usual set up is stbd is house. You can easily check by switching off stbd battery switch and checking your panel (or engine room light) while switch is off.
    Your engine provides the negative path.
