4588 pilothouse overhang rot-gctid825716
    I'm looking at a 4588. It has rot/softness on the underside of overhang of the flybridge, above the pilithouse windows.
    All other deck areas are good. Is this easily repairable? Diy, or sign of deeper problems there?
    [attachment=41511
    "All other deck areas are good. Is this easily repairable? Diy, or sign of deeper problems there?"
    That area is fairly easy to repair and the problem is typically a leak from eth drip rail on the front.
    If all other wood areas are good I would suspect someone has taken great care of the boat or that it has had repairs completed in the past.
    Here are a few of the areas that can become problems due to wood on the 45.....
    - fly bridge deck all
    - bow winch back to the seat deck area
    - Arch
    - Fly bridge seats
    - Fly bridge deck
    - Wood behind windows on the sides of the Pilothouse
    - Davit base and sides
    - fly bridge overhangs on the sides
    - Strut bolt anchoring locations
    - these wood platforms below: the water heater(s), fresh water tanks, holding tank, batteries, AC units, etc
    Hope this helps
    - engine stringers (rarely a problem)
