New strut install-gctid825433
    Any tips on bedding compound and do I need to shim them or just align the engine's
    Bob
    2001 Bayliner 3988 330 hp Cummins 6bta m3
    950
    Located in Blaine Harbour Marina
    You really want the centerline of the transmission output shaft and the propeller shaft to be in the straightest line possible. IMO, it would be worth having a shipwright with the laser alignment setup to work through the process with you.
      It may or may not need to be shimmer. If it was previously was.most likely need to. Things move and change you won't know until you do a preliminary fit. Some shims are flat some are slanted.
      1989 Avanti 3450 Sunbridge
      twin 454's
      MV Mar-Y-Sol
      Twin chevy 350's inboard
      Ben- Jamin
      spokane Washington
        Remember; your final shaft alignment needs to be made in the water after it sits for a day, this allows the hull to settle in some.
          5200 seems to be the sealant?
          I have the pattern for the 3988 Strut if anyone need one.
          950
