My Starboard kill switch suddenly kills both engines! In the cabin but not on the fly bridge. What's happening?
1987 3270 engine kill switch-gctid825085
Sure sounds like a short somewhere...trace and check the wiring, clean the connectors with contact cleaner spray. Maybe some of the wiring is touching the port engine somewhere and insulation has been melted off or something? Check that the kill switches are wired correctly too. I'd assume that (like the EH-700's) the kill switches activate a solenoid that pulls a lever forward to shut the fuel flow off (on the EH-700's, it's on the port side of each engine). Look in the engine room and listen while someone pushes the starboard kill switch, and see if the solenoid on the port engine is activating when the starboard kill switch is pushed.
HTH,
I have noted in the past that some mechanics and electrical technicians take short cuts. Some of them connect both engines to a single kill switch, leaving the second kill switch as a "dummy".
Reading your message: "suddenly" refers to the fact they did work separately in the past, which obviously would discredit my theory though.
Tracing the wires from the kill switches would determine if they are separately connected or wired to the same kill switch...
Good Luck!
1992 Bayliner Trophy 2502 WA
2010 Twin Suzuki 140 HP OB's
"Always finding improvement projects on this old lady..."
"Gsherwood" post=825311 wrote:
You have kill switches? I have a 1987 3270 and I don't. Did you or a previous owner add them or were they factory?
"Martini's Law" SOLD
Nova Scotia, Canada
"businessgetmoney" post=825339 wrote:
Only the diesels have them? And they function by killing the fuel? That does not seem ideal
Charleston, S.C.
Because running a diesel out of fuel often requires purging the fuel system. Maybe these diesels are different but at a repair shop I use to work at mechanics would have to tare down engines and spend hours to get them started again.
To be honest tho, i really have no clue how key off terminates a diesel engine so maybe its just on older or semi truck style engines.
1993 formula pc 31 twin 454 bravo 2
1989 2655 cierra 5.7 omc cobra
2014 "searay" tandom trailer
Anchor bay clinton river
Michigan
Charleston, S.C.
