Hi guys. Got a call from a friend tonight who's on the hook in an anchorage that has a 4-5 knot tidal flow. After a while he heard an unusual noise and thought some pump was running, so he went hunting for it. However it wasn't a pump, it was the port prop shaft rotating from the current flow. The starboard shaft doesn't move and there doesn't seem to be a mechanical issue with the functioning of the gearbox and nor do the dripless shafts leak during the rotation.
I've never heard of the issue and thought a cutlass shaft bearing had too much play and needs checking. Has anyone heard of or had experience with the same issue.
Thanks much. Cheers
Thanks much. Cheers
