3988 bowsprit
    3988 bowsprit
    Successfully performed "pulpitectomy" last week on my 3988. A couple of notes:
    1) got lucky and did not find 5200 under the bowsprit, just sealant and all was dry inside so the removal was minutes instead of hours. FWIW this boat was build in Valdosta.
    2) Guy at Railmakers Northwest is the best, would not hesitate to recommend him if you take this project on. At his suggestion I will be riveting the new rail piece instead of drill/tap
    3) Windline brm3 anchor roller fits perfectly with 44# delta plow, the manufacturer only listst up to 35#
    4) I have a bowsprit in good condition if anyone is looking for one...
    Thanks to all who posted on their surgical removal of same; it was of great help when preparing for the project.
    I removed the bowsprit off of my 3988 some time ago, have patched things up with epoxy, purchased a 44 lb. Bruce type anchor and brm3 anchor roller. I've made up a template bowsprit out of wood and am still debating on which material to use for the final pulpit. My initial thought was Starboard, but I'm considering using 1/4" polished stainless instead. In regards to the bow rail, another 3988 on my dock also performed the "pulpitectomy" and had a section of stainless rail welded on by a skillfull stainless guy: you can hardly see any seams and it looks great.....I'll probably do the same.
    My question is, what material are you using for the actual pulpit? Pictures?? Ideas??
    Alex
    Orange County, Ca.
    2001 3988
    Twin Cummins 330's
      Just curious...why are you cutting off you pulpits? Are you trying to fit into a smaller slip?
      Greg
      1999 Bayliner 3988
      Twin Cummins 6BTA 270hp
      Malaspina Strait, BC
        To my eye the bowsprit makes the boat look dated. It is out of proportion to the rest of the boat and really serves no useful purpose. I have also experienced a lot of chain jumping at the gypsy when the rode wags back and forth in the 3-4 ft of span between the roller and the winch. Dockside testing has shown a big improvement in this, field testing will be next week.
        And finally, I now have the option of either a smaller slip or keeping the one I have and tying my skiff across the transom while staying within the bounds of the lease.
          I also prefer the look of the boat without the long nose. With that said, a big factor was also the ability to go into a 40 foot slip vs. 45 foot; a savings of about $125/month.
          Alex
          Orange County, Ca.
          2001 3988
          Twin Cummins 330's
            Out of curiosity, what is the LOA of a 39 without the anchor platform?
            2013 Boston Whaler 130 SS
            Isla Verde, PR
              Norton,
              my 39 measured in at 42'3" without the original bowsprit. Once my modification is completed, I figure I'll be adding between 1' to 1 1/2'.
              Alex
              Orange County, Ca.
              2001 3988
              Twin Cummins 330's
                "Ahaua" post=825058 wrote:
                Norton,
                Thanks for the info. That will make the final LOA just a few inches longer than my 3788. I ask because I have a buddy in my marina with a 3988. He owns a slip like mine: 45' LOA max. In order to meet the LOA requirement he has to remove the tender that he carries on a Weaver Leaver Davit and store it on a trailer. Removing the pulpit should allow him to keep the tender on the davit while the boat is in the slip.
                Isla Verde, PR
                  Hope this old thread has life. Do you still have the pulpit? Mine is in need of a rebuild. Also, how about a pic without it installed please.
                  mike.
                  3988 Cummins
                    Pulpit is long gone but another member is considering the same procedure, will let him know you might need it.
                    • Ahaua
                      Ahaua commented
                      Please post pictures of your completed project.....would love to see it!
                    Thank you.
                    3988 Cummins
                      I am doing the pulpit removal soon and will have a pulpit available June time frame. Should be in good shape.
                      Guntar
                      1999 3988
                      Cummins 270s
                        where are you located? and i would like to see completed pics.
                        3988 Cummins
                          Seattle. I'll post when done.
                          Guntar
                          1999 3988
                          Cummins 270s
                            seems like most owners remove due to size limitations? and or cost?
                            3988 Cummins
                            • Ahaua
                              Ahaua commented
                              I initially did it to be able to fit into a 40 ft. slip, but I really like the look of the boat without the long bowsprit.....have gotten many complements on it. I would do it again in a heartbeat!
