I have full fuel tanks (1400)200 gal diesel @ 7 lbs plus my 310 Avon 15 hp outboard aprox. 300lbs *on the transom mounted on the tilt Davits in a horizontal position.
With full water 50 gal @ 8 lbs this is another 400 lbs. 125 ' 5/16 chain rode plus two anchors on the bow. 35lbs Delta & 33 lbs Bruce. We are loaded for bear. Taking a voyage. Plus supplies loaded in the front cabin.
I have known that when I am loaded for bear the vessel is heavy...
I usually don't run around with this much fuel except at the start of the season. My question is ? the water line Just at the stern is below the water. About 2 " Have other 32xx experience this.
Looking for some feed back.
