Does anyone know a good source for reconditioned or new 1986 3270 Hurth 360 transmissions. Preferably in Canada, but probably unlikely. Just checking for a fellow boater. Not sure what the difference is between 360 and 360a. Is there a re-build kit for these? Any pointers would be appreciated.
Hurth 360 Transmissions-gctid824396
The "a" is for down angle. You can still get the typical wear items like the thrush washers, but any of the major parts are obsolete. A good source is Mike @North Harbor Marine/Diesel
2019 Cobia 240 CC
2006 Boston Whaler 13 Sport
1985 3270/Hino 135s (Sold)
Vero Beach, Fl.
Steve
1987 3218 (sold)
135 HINO
2016 Past Commodore, Swinomish Yacht Club. La Conner Washington
When I did the math, a new ZF-630A was about $50 more than the cost to rebuild a Hurth 360A. I swapped both of my 360's to new ZF-630's after one of my 360's let go due to a bad thrust washer. The 630's are a bit shorter , but they fit nicely.
Make sure you replace the drive plates when the gears are off - I bought R&D polymer ones which work great, but the 630's sound like a couple buckets full of marbles when idling - not much you can do about it...
________________
1998 Bayliner 4788
1989 Bayliner 3270 - SOLD-
I have a rebuilt 360a 1.65:1 ratio that came out of my Dad's 1988 3218. We had it rebuilt before going with a total repower, transmissions and all. It's been sitting here since.
I am just out of Vancouver (Langley, BC) if that helps.
LCexplorer. I have a buddy just bought a 32 with a slipping 360a. I'm not sure of the ratio but will look this weekend. Who did you have rebuild yours? What is your price? I am in Kelowna so if the deal is right I'm sure he'll take it. Text me if you like 250-212-3586.
Nikko and anyone else with the bucket of marbles......you don't have to live with that racket!!!! When I bought my 32 it drove me nuts! I changed the drive plates. Installed the R&D plates first but they were worse than the old plates. Advise from fellow boc members and talking to Mike (the transmission guy at harbor marine) changed to centa flex plates.....they are beautiful. Quiet and shifts with no cluck rattles etc.
1987 3270 MY
135 hp Hino's
Kelowna, BC
See Nikko comment above: the experts in the Seattle/Everett area would be Harbor Marine in Everett. Highly recommended. Note the Nikko comment about replacing the drive plate also, particularly if anyone else has a commins engine.
1997 4788 with Cummins 5.9 (315 hp)
12 ft Rendova with 40 hp Merc 4 cycle
Pacific NW
"Nikko" post=824480 wrote:
When I did the math, a new ZF-630A was about $50 more than the cost to rebuild a Hurth 360A. I swapped both of my 360's to new ZF-630's after one of my 360's let go due to a bad thrust washer. The 630's are a bit longer, but they fit nicely.
Forward thrust washer $164
Reverse thrust washer $58
Paper clutch disc $93 ea
Steel clutch disc $66 ea
And as you say, the upgrade to a new transmission is only $2200. FYI- When I asked Harbor Marine about any shaft length issues, Mike stated 'The 630's are shorter by .787" so we use a drivesaver that is 1.00" thick.' for cost of $560 for the pair. The only negative appears me is the increased parasitic power losses of the upgraded transmission as noted by others on the forum. For what it's worth, Dean
http://www.merequipment.com/products...60a-parts.aspx
I bought the first one from harbor marine.... 307 usd. This was 5 years ago though.
Second one I bought from First choice marine online part #CRU-R140019 ....264 usd same thing 5 years ago. Not sure of today's price
Anybody know what the difference between the port and starboard transmissions? The 360a
cheers
Kappy
1987 3270 MY
135 hp Hino's
Kelowna, BC
1987 3270 135-Hino
Foxtrap, Newfoundland
OK, I was thinking about drive savers like these...
http://www.defender.com/product.jsp?...9131&id=590663
1987 3270 135-Hino
