Hello,
I have another question about my 1986 3270. On my dash at the main helm, I have a switch labeled "Accessory". When I operate this switch, I hear a pump run and have a flow of water coming out of a thru-hull that is the furthest forward on the starboard bow and way up above the water line. I let the pump run for quite a while and the flow did not reduce volume any. It seems that I may be pumping out my freshwater tank. Does anyone know what this switch is doing? Does the freshwater tank have a pump on it that would be pumping it overboard? I have done this several times for almost 5 minutes a time and the volume continues. Any body else have this switch/pump combo?
Keith
Keith
