Barely had enough strength to remove the port starter (eh700t 4588 '88). Any tips on installing this behemoth after rebuild?
Starter installation-gctid823765
One thing to try is longer bolts with the heads cut off and some flats ground in. These will act as studs to hold the starter in relative position while you install the bolts swapping out the studs as you go along. If there's a way to suspend the starter or even hoist it in place, even better.
