Are 38xx bilges connected at some level?-gctid823640
    Just curious if forward bilge will drain into rear at a certain level (and vice versa)
    Only when there's way too much water inside. :evil:
      the two bilges are separate. each has a crew operated electric low water pump
      and an automatic float switch activated electric high water pump.
      if you flooded your engine room bilge with a garden hose, it is not going to fill
      the forward bilge. you might do it in order to test to confirm that the separation
      wasn't modified by a PO. also another reason to do it is to clean-out debris from
      the bilge which can get stuck in the bilge pump impellor. attempts to have a truly
      dry bilge can result in the debris fouling the pump as the last bit of water is pumped out.
      Novurania 335DL. 30HP. WKRP in cincinnati. Previously: Bayliner 3818 in PNW.
        As in above the floor? :P
          Front wall of bed is separating bulkhead....
