Advice needed on an 8.0kw generator.
Like every single time, I boarded the boat and started the generator to charge the batteries (I'm on a mooring right now). I peek over the side to confirm water discharge and look at the gauges for proper operation. The water discharge appeared normal. After about 40 minutes of running the generator shut down by itself. Ran fine for 2 hrs last weekend. I knew fuel was not the problem. I felt the raw water pump with my back of my hand and it was very hot. Too hot to touch. I decided to rebuild the raw water pump and started the engine again. Now a week later, the engine started right up. I peeked over the side and the discharge looks normal. After reaching 180 degrees, I removed the fresh water fill cap and watched the water circulate. The temp gauge reached 200 degrees and I shut the generator down.
Here are my questions -
What is the normal operating temperature for this generator? (Could the overheat sensor be faulty)
Can the fresh water pump be tested for proper operation without removal?
Am I getting in over my head to clean out the heat exchanger or is it pretty straight forward?
Thanks for any advice.
