I just removed a thin, partially adhered bead of caulk from the top of the rubrail to hull seam. The seam looks pretty darn tight. I am wondering the neccesity for this bead of caulk. What do you all think?
4788 rubrail caulking question???-gctid823519
Clean out all of the old caulk, clean the surfaces as deep in the seam as you can, then PUSH the caulking gun along to fill as much of the gap no matter how narrow it is. Never pull a caulking gun. A pulled caulking gun will not fill the gap, but rather lay a bridge of caulk across the top of the gap. It won't last long. You may already know all of this but it is worth stating for others who may read this thread. Recently did this on Mr. Darcy. There... my two cent comment is done.
Greg
Newport, Oregon
South Beach Marina
In a perfect world, all of the fasteners for the rubrail will be totally sealed, eliminating the need for additional caulking.
In the real world, I agree with other posters that an additional bead of caulk along the top edge would probably be the way to go, but only if you prepare the surfaces well.
Chasing a leak last winter, we ended up removing all of the rubrails and starting over, resealing every nut, bolt or screw along the way. We found several holes drilled through the shoebox join that were supposed to have a nut and bolt inserted, but someone 'forgot' at the factory. Upon reassembly, we did in fact lay an additional bead of caulking along the top edge.
Whatever you do, take the time to thoroughly clean and mask for the bead you are applying.
Rob
Bayliner 5788
'Merlin V'
Vancouver BC
On a previous boat I calked the rub rail by removing a couple screws, pumping calking in one until it came out the other and then removed the adjacent screw and moved down the line. This forces the calking into the hull deck interface as well.
1997 4788 with Cummins 5.9 (315 hp)
12 ft Rendova with 40 hp Merc 4 cycle
Pacific NW
If the rub rail doesn't leak into the interior...I wonder if it is worth caulking. I believe it is an all or nothing caulk job. Water will get in some how and get trapped if you only partially caulk it. I'd venture a guess to say that it might be better to leave it uncaulked so any water might work it's way out.
I am currently replacing the factory rub rail. I plan to remove all the screws holding the joint together and re-install with 5200 to avoid them loosening up. Then I will caulk the seal from underneath the joint and fill all the original rub rail screw holes. Then install the new rail and use sealant on those screws as well. I did not plan on caulking the rub rail.
Gibraltar, Mi.
1986- 3870- Hino 175's
1988 26' Shamrock/ Diesel
14' Zodiac Bay Runner
CLEAN doesnt mean "wiped off"... use lacquer thinner, xylol, or acetone and clean it well and the caulking will adhere to the surfaces for the life of the caulking, or boat, whichever comes first...
make sure the cleaning chemical is completely wiped of and traces evaporated before applying the caulking, because these chemicals can have a reaction with the caulking
MASKING the rail and hull with tape is the only way to get a clean and professional looking job (unless of course you ARE a professional and have used a caukling gun enough to know all the tricks).... the nice thing about masking is (other than it being much cleaner), after masking the area about an 1/8" of an inch either side of the seam, you can push or pull the caulking gun while laying the bead, THEN run your finger down the bead firmly to PUSH the caulking into the seam while at the same time smoothing the caulking.... if you get a spot that is open and needs more caulking, you can easily lay another bead and smooth more of it into the seam without making a mess like is normal when no masking tape is used.....
remove the tape as soon as the seam is filled to prevent a dry tape line that may try to lift with the tape..... then use a wet finger (i like to use a bit of soapy water to wet my finger) and run it very lightly along the still wet caulking to smooth any tape line..... its perfect job every time and much simpler and cleaner to achieve than when trying to caulk without tape..
after masking and before applying the caulking, I use a scotchbrite pad to buff the seam lightly, then wipe it clean again... I feel this insures a longer lasting grip as there is no chance of any oxidation left between the caulking and the gelcoat.
NU LIBERTE'
Salem, OR
5.7 OMC Cobra - 15.5x11 prop
N2K equipped throughout..
Hope this isn't too much of a hijack...while cleaning this area I noticed sealant was peeling away and I'd like to reseal to prevent water getting in while underway. Water hits this area pretty hard at cruising speed (kind of a silly design). Ideally I'd like to put a deflector shield of some sort, in the meantime what is the best sealant to use - 4200? Thanks
2001 3788 w/ 330 Cummins
Seattle, WA
NU LIBERTE'
Salem, OR
