AC issue on 1989 3818....-gctid822815
    The main cabin AC temperature (as measured with a laser thermometer on the vanes on the air flow duct) is about 73 degrees (outside temp of 85-90 degrees). I checked the 2nd AC for the staterooms...temperature at the air duct is 61 degrees, so it's definitely not performing the same. Water flow looks fine (I'll check/clean the sea-strainer this coming weekend), and the temperature of the water expelled from the mid-ships thru-hull doesn't feel particularly hot (just warm).
    What do you guys think? Needs a refrigerant recharge? Or something else?
    Another question: Where IS the main cabin AC/heat unit? It's somewhere under the inside helm, but I can't see it. Is it behind the fridge (such that you have to pull the fridge out to access it), or tucked under the "false floor" directly beneath the starboard side of the inside helm?
    I don't know a lot about AC units, but I did manage to identify that the thermostat had failed a couple months ago, and replaced that myself. It was working fine for the past couple months, and now we've just noticed it's not cooling particularly well.
    Thanks in advance for any advice/help!
    What's the issue? It's 73 inside and 90 outside? Sounds like it is working to me If it's not cycling like you are expecting, realize you are trying to cool off a non-insulated plastic box. Mine will cycle in an approx. 15 degree difference between inside and out (kind of depends), but when the sun is up and beating on the boat, it will just run and run...unless I turn the temp up to get within that window.
    I would say they are fine. Do you have electronic controls or the old school dials? I have dials in the master stateroom, and a newer unit with electronic controls in the salon. I can actually see the temp I set mine too and then monitor it against and indoor/outdoor thermometer I have. It's pretty slick.
    Salon AC, on my boat, is under the hatch right behind the lower helm. The intake grill is in that wall. The outside of the wall is the hull which is one reason why it has trouble cycling in temperature extremes.
    Master AC, on my boat, is up forward under the bed.
      The temp at the air vent where cold air blows out is 73...it's about 85 degrees in the salon with it around 90 degrees outside, however. The temp from the vent should be low 60's, like the master stateroom AC. The thermostat seems to be working fine (old manual dial type)...the compressor is cycled on almost all of the time though. Again, it sounds like low refrigerant to me. And no, it's not working as it should or as it has been for the past year.
      Hmmm...I don't think I HAVE a hatch just aft of the lower helm...but I could be wrong (maybe there's one there and I just don't know it...the prior owner put in some flooring without making provisions to open the floor hatches). You're NOT referring to the main hatch over the starboard engine in the salon but a 2nd salon hatch just in front of the lower helm, correct? I'll check this weekend.
      Thanks!
        Oops! I must have misread your post then inch:
        But I can help with the salon AC...at least its location on my boat! Here is a picture:
          Not totally clear on what you are measuring?
          Normally you measure the air temp at the inlet and the outlet. 20F difference is good. 15ish is OK probably needs coils cleaned. Less than that REALLY needs cleaning or leaking/needs recharge. If you look at the coils what indicates needs cleaning is the whole thing is frozen - not enough airflow. If its only frozen or cold at the bottom then recharge.
          Both my 1987 units are toast at this stage. I've replaced the aft unit with a new one and the forward one I am limping along with a recharge at the moment.
            Cool Beans, thank you for that pic! I had no idea there's a hatch there...the prior owner's flooring has it completely covered with no provisions for opening that hatch (I'll change that). I knew that AC unit was in there somewhere, just couldn't figure out how to get to it!
            Kev_rm...thanks for those details, much appreciated!
            Anyone know what refrigerant these older units use and if it's even still available? I'm assuming it's available, but probably ridiculously expensive...
            Cheers,
              No problem! Makes you want to smack the PO right up side the head, right?
              LoL
              OLD hvac might be R12...My forward unit is 20 years old (not factory original) and is R22 I think...it has a bad pressure relief switch that I bypassed and some other issues. It works, but I don't want to go into winter living on the boat when I will need the reverse cycle heat. So, today I finally ponied up the dough to buy a new FCF Webasto 12k BTU reverse cycle unit with the new fancy quiet compressor and R410a refrigerant. Digital controller, no more knobs, dehumidify cycle, should be drop in. $1500 shipped from Defender. Not gloating, but kind of :whistle:
              EDIT: The point of my post was along the lines of the advice I got from Trawler Forum when I asked about repairing my old forward unit. I was going to spend $500 to repair a 20 year old unit. If it worked, I still had a 20 year old unit I spent $500 on 20 year old anything really owes me nothing, so...time for new
                Its more than likely it's R-22 which at this time is $850.00 dealer cost for a 30 pound cylinder. These marine systems typically hold between 3 and 5 pounds.
                The temp drop should be about 20 degrees towards the end of the cycle.
                1988 Mainship 36 Sedan
                1995 2858
                1988 2655
                1987 2150
                Commercial/Industrial HVAC Service Tech.
                  Cool Beans...this one? http://www.defender.com/product.jsp?path=-1&id=2846502
                  You made some good points about the age of the units...
                    I dug into that hatch last weekend (thanks again for that pic, Cool Beans). Unit is easily accessible when you know where the hatch is. :P
                    Nothing frozen I could see, and now only about a 5 degree temp difference between in and out...definitely sounds like it needs a recharge. For it to degrade this quickly though, I'd assume it has developed a refrigerant leak. It uses 17 oz of R22...it might be worth picking up a 15 oz can (around $50 or so) and recharging it to see if I can get another season out of it.
                    It's a 16K BTU unit (main salon...MarineAir model VR16K-H), which I'd assume is probably the original and thus 28 years old. Any suggestion on drop-in replacements?
                    Cheers,
                      If you are not reading 57 degrees out the exit of the vent the unit is not cooling to capacity. I live in hot, humid Florida, 93 and 80% humidity all summer long and both ACs read 57 degrees as the vents. Water temp is 86...
                      FYI: I purchased that Webasco unit about 18 months ago. It works, but not the greatest. My 1997 vintage Cruise Air up forward is a much better unit. If I could do it again I would spend more to get a better quality unit. The digital display is junk, the remote stopped working.
                      2019 Cobia 240 CC
                      2006 Boston Whaler 13 Sport
                      1985 3270/Hino 135s (Sold)
                      Vero Beach, Fl.
                        No air conditioning unit on the planet would measure 57F w/ 110F input. Need to Measure the difference.
                          Ok: AC vent 58, water temp 84, outside temp 99.
                          2019 Cobia 240 CC
                          Vero Beach, Fl.
                            Ok, 58 at the vent, 84 water temp, 88.9 in the AM
                            [attachment]41687 wrote:
                            58.gif[/attachment] [attachment]41689 wrote:
                            water.gif[/attachment] [attachment]41688 wrote:
                            outside.gif[/attachment]
                            2019 Cobia 240 CC
                            Vero Beach, Fl.
                              Your welcome Dave! I would have had my Webasto installed a couple weeks ago but I'm 2 for 2 in damaged units incoming, trying for a third coming in next week, lol.
                              What kind of temp gun is that and where did you get it? That things is pretty slick!
