We have a 3988 and would like to hard wire up to 4 engine room cameras to the helm. Ideally it would be nice to have them displayed with a split screen on a laptop and have the ability to display a single camera for better detail. Does anyone have any suggestions or experience with this project? Thank you.
Engine Room Cameras-gctid822134
I have dual cameras in my engine room running through my garmin 8000 and 7600 series screens. They work ok, but this winter I want to get rid of them and install two flir ax8 cameras. They are expensive but can be programmed to alarm on various parts of the thermal image. For instance, you can program the heat point of your exhaust to alarm on the screen if it detects your programmed upper limit. It opens up the value of the cameras from curiosity to pure function and safety.
Here's a link... http://www.flir.com/marine/content/?id=71005
I hope this helps,
BJ
OMEGA
5788
BJ
OMEGA
5788
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
"ksanders" post=822152 wrote:
I use Dlink cameras, available on Amazon for less than $100
The connection is wireless, and I can access the cameras from onboard, or from my ipad or computer, or even iphone from anywhere.
I'm sitting at home right now, and these photos are live.
[attachment]40396 wrote:
Esteban
Huntington Beach, California
2018 Element 16
In all seriousness, it is really handy when you have a boat sitting at a dock, unattended most of the time to be able to check on it remotely.
I not only have cameras, I have a full on status and alarm system that alerts me to any issues, such as smoke, high bilge water, shore power being disconnected, battery charger failure, and a host of other things.
Flir camera model M series MD series are supported, FLIR M-Series cameras require the firmware package version 2.5.8 or newer.
Most Garmin 8000 series are supported, Supported GPSMAP 8000 Series MFD's will require software version 4.0 or newer.
[/quote]
I think you need more hobbies if you sit at home and watch your engines![/quote]
Thanks! Too funny!
I not only have cameras, I have a full on status and alarm system that alerts me to any issues, such as smoke, high bilge water, shore power being disconnected, battery charger failure, and a host of other things.[/quote]
Yeah,
I could of used some of those this winter when I found evidence of someone sleeping on my boat. Instead, I went every night and morning to the boat trying to catch the bum.
Esteban
2018 Element 16
"Sunnydude" post=822190 wrote:
Kevin...do you need to have a router to use the cameras while onboard? I was always wanting to install some cameras in engine room to monitor filters and such.
Having a router on board opens up the world of possibilities
Be aware that the resolution on IR cameras is typically MUCH lower than on visual range cameras. There won't be a lot of detail. Also, the emissivity (effectiveness of emitting energy in the IR range) of various parts of the engine can vary somewhat depending on the material and coating (paints/oil) as well as the temperature, which can alter the signal a bit. IR cameras are very good for giving an indication of relative temperature and picking out hot spots, especially once you get used to what "normal" operating temperature patterns appear like.
Lake Memphremagog, Newport, VT
2015 Bayliner 175 BR
Mercruiser 135/3.0 MPI Alpha One
"iceclimber" post=822569 wrote:
Kevin are you joined to your Marina's internet ?
