I would like to align the twin 250 hp hino engines and prop shafts on my 4588 boat, anyone with specifics I would appreciate information
alignment of 250 hp hino engines in 4588 bayliner-gctid822096
You will have much more luck getting answers if you post this in the motor yacht forum. Good luck
Capt. Ron.
"Never Trade Luck For Skill"
Hino EH700
Westerbeke 8.0
There are several levels of alignment. The most basic is the gap at the transmission coupler. There are several YouTube videos about how to do it but basically you are looking for an even spacing between the plates when butted together and the bolt holes align from side to side. Not to be presumptuous, but if it were me asking the question, and this is my personal plan, I'd hire a very knowledgeable person to do it and show me at the same time. The last time I did it was in '68 to a 27' Fairliner so I might be a bit rusty. The second, most definitive alignment is laser. This is done by placing a projector in the cutlass bearing and centering on the center of the transmission output shaft. Then the coupler alignment follows.
Sorry I can't be of much help. Maybe Smitty477 or Earl International can offer up some closer advise.
Edit: later last night I read about the procedure in a book named "Boatowners Mechanical and Electical Manual" by Nigel Calder. I recently purchased the book on the advice of my Marine Electrician to help me chase down a less than 100mA ground fault but am finding the book is much more than I purchased it for. It has a detailed description of how to align the engine and shaft as well as common situations that need to be dealt with. I bought it on Amazon for about ten bucks plus shipping. If you would like, pm me and we can set up a phone call and I can go through it with you.
