Recently I discovered why I use so much water, a leaky tank.
I was able to see the major leak area from the port stateroom bilge pump access.
The leak was just under the supply fitting and was about 2 1/2" long on the weld.
I emptied the tank and let the water drain then put 3 large coolers of water on the bow then used a heat gun to dry the area.
I then sanded the seam and used 2 layers epoxy and 2 layers of the sealant that is advertised on TV on a boat bottom, I let it cure and re-filled the tank, still have a slow leak or leaks but doable for now.
I will tear up the floor before I leave Seward, AK and take the measurements.
I intend to build 2 tanks to fit out of Vinyl ester resin and fiberglass and install pads to fit the pipe threads.
After layup I will heat the tanks to 160 to 180 for 6-8 hours to drive off the gasses and that should leave the tanks to be used for water.
I will take photos of the layup and finished product and the installation and post it.
I will try and make the photo's posted so they can be copied.
I need to build a 12' x 16' extension on my shed for a more doable workshop, with a portable air conditioner so I can layup an item with out the heat curing the resin to fast.
I will be leaving AK at the end of August and drive back to Florida.
boatworkfl
boatworkfl
