3988 House Water Pump-gctid821098
    Hi all, anyone know the make and model of the 3988 fresh water pump ? Thanks for the help.
    I replaced mine last year with a FloJet 04405143A (same one that was in it when I bought the boat)
    Works great.
    Flojet 4405 Series Water System Pumps deliver smooth, consistent flow without the need for an accumulator tank. Features: Internal bypass feature eliminates pulsating water and pressure switch noise Services up to (5) outlets Pump can run dry
    Greg
    1999 Bayliner 3988
    Twin Cummins 6BTA 270hp
    Malaspina Strait, BC
      Update: I finely got a look at my existing pump and it is a FloJet R4515-715 which is no longer manufactured. The recommended replacement is a Jabsco 42755-0092, both are 12V variable speed pumps. FloJet, Jabsco and Rule are all part of the same cooperation. Since my need is for a spare and the variable speed pumps cost about three time the one suggested by Cap_Fury, I'm going to acquire a FloJet 44051-143. Thanks for the help.
        Since you are replacing a pump anyway, take a look at the post I just put up (Recomended for all Larger Bayliners - Domestic water pump). You might as well add a second pump while you are at it.
        Alan Teed
        MOONSHADOW
        1996 Wendon Sky Lounge 72'
        Gig Harbor, WA
        Previously:
        1994 Bayliner 4788
        2006 Hylas 49' SY
        Bayliner 2855
        1977 Cal 34' SY
        1981 Hunter 33' SY
