4588 250hp hino-gctid821076
    does anyone have the jabsco equvilent impellor number for the
    raw water pump? 1990 hino 250hp.
    thanks
    Well yes and maybe. There are two different water pumps I am told. we ahve the EH700TI . If you have the Kashiyama then the jabsco is 31130-0061
    https://www.fisheriessupply.com/jabs...e-31130-0061-p
    I have been told some have replace the pump with others models/brands so this would not fit if that is the case
    ps you will need make a paper gasket since jabsco does not come with right one. or purchase from these guys
    https://www.marinepartssupply.com/engines/hino
    https://www.marinepartssupply.com/book/18/633/
    Mark
    USCG OUPV
    1990 4588
    Carlsbad, CA
      thanks
      I believe you have the WO6 -DTI -I 250 Hp Hino.
      We never had those engines but I have heard the impeller is slightly shorter than the ones i used on the 310 Hp wO6D-TI-II
      For the 250 hp I believe that would be an 08-1028B but perhaps google "Hino 250 Hp raw water pump BOC" and see what comes up from past owners.
