I'd like to replace my mess of 50-30amp adapters on the the boat going to 30 amp cords to a 30-50amp y-adapter to the dock supplied 50/250v with a single 50/250v Smart Plug. Boy, if anything screams "fire hazard"....
Being a live aboard, I can pull some amps! Yes, I juggle when needed. If understand this correctly, going to 50/250 means I'll have 100 amps @ 125v available?
So! Has anyone performed this conversion? And how easy was it? In my head it should be grounds and neutrals go to their own terminals and each hot goes to it's own terminal...but this is a boat project, so I assume it is more complicated than that :S
Thanks!
EDIT: My boat has dual 50/125v inlets which has lead to a number of adapters and connections outside the boat.
Thanks!
