Blower location 3870-gctid819855
    Need help locating the blower on my 1985 3870 I have a switch that lights a light but no sound.....but I have no idea where to look for the blower motor
    They are under the vent baffles on the starboard side
    I haven't figured out how to change them as you can see them but can't seem to get to them.
    Terrible placement - mine have never worked - easy to be soaked with water.
    You can see them from inside if you get on the starboard side of the starboard engine - like you do when you change the filter.
    Ron O'Blenis
    B 38 175 Hinos 1989
    Completed Great Loop
    https://ronandfaye.blogspot.com/
      Mine are also under the forward vent grill on the starboard side. If you remove the forward grill you can see both of them, and how they are mounted. They are accessible from beside the starboard engine, mine has a gap on the floor under the wet bar, it doesn't go right to the hull side. It would be a job to replace them though, I'd recommend removing the grill.
      James
      Hurth 630's Onan 8kw MDKD
      Lowrance Electronics!
      AGLCA #8340
      MTOA# 7469
        Ok I guess I'll take the grill off next Saturday. I'm guessing mine are froze they don't make a sound. I'll try to get a look by taking off the grill first I hope I don't have to get between the engine and the bulkhead. Thanks for responding
          they are not easily accessible from inside the ER.. take the grill off from the outside and its right there.
            Make sure they are getting power, not just a bad connection
