I just had a rebuilt 5.9 Cummins 270hp installed and when you start it, it smokes , is this a common thing until it is broken it?
New Motor-gctid819751
Jim,
It has been my experience that Diesel engines smoke initially upon starting but should clean up after they get warm. That can take a minute or so. Certainly give it some time to break in. Was the fuel injection system rebuilt including injectors?
Bob and Lulu
1997 5788 'Starship' MAN 610s
1996 3988
1993 3058
Vida, Oregon
Every Cummins marine diesel I've ever had smoked on startup
This should clear up as the engine warms up.
Hopefully you were briefed on how to break in a Cummins engine.
If not, its simple. Run the engine hard. Dont idle the engine, get after it when underway.
Whats the weather like on the boat https://www.weatherlink.com/embeddab...59665f4e4/wide
Water entered the starboard engine last winter from a sea surge.We are doing a sea trial Tues and I will post pictures later.
