Now that marinas are installing the new 30 miliamp GFI breakers, I'm having a problem connecting to shore power. The attitude of a couple of marinas is that I'm some sort of a scofflaw and should fix my boat. I finally found somebody to explain why I suddenly can't plug in. There was a change in the code that toook the allowable miliamp crossover, aka ground fault, from 100 ma to 30 ma.
So, with that bit of knowledge, I now at least understand why I blow the new fancy breaker as soon as I turn the shore power on, just not why. Maybe more like where do I start searching. I shut down all of the downstream of the main shore/off/ship switch and then turn the switch on and most of the time it holds until I turn on either of the two master breakers.
If this were in an outlet circuit, that at least cuts it to one area, but I'm at a loss at where to start looking. Have any of you run into some usual suspects?
I'm going to build a short cord with one of those 30 ma breakers that I can fit in line so I don't have to go to a marina with the new setup and run back and forth while I try things out.
