EH700 175hp raw water impeller replacement...Kashiyama pump-gctid818703
    My impellers were last changed 4 years and 530 hours ago. (BTW, the old impeller still looked great)
    I have always hired a mechanic to do the replacement for me. This time I thought I would do the job myself. So, this morning I went to the boat and replaced the starboard impeller without too much problem. On my 3870 access to the starboard pump is easy.....but when I now look at the Port pump., if I lay between the engine and batteries I can reach in to the pump with one hand...I'm not sure I can do it myself.
    Those of you who do this on your own....what suggestions do you have, how do you manage to do it?
    Thanks for your suggestions
    Allan
    1986 - 3870
    175 Hinos
    Moored in Ladysmith BC
    Our resident expert, Earl "The Bayliner Guru", suggested, when I asked, that I lay between the motors and loosen the bolts underneath then you can lift the pump to a place you can get at it.....or so he said. I haven't tried it yet. Some here have said they remove the hose connections to get the pump to an even easier place to take apart.
      I lay on top of the port motor from between the engines and reach under the mount with a wrench to loosen the 4 mounting bolts. I then loosen the tension on the belt and remove it. I then remove completely the 4 mounting bolts and lift the pump out and take it to my workbench to overhaul.
      James
      Hurth 630's Onan 8kw MDKD
      Lowrance Electronics!
      AGLCA #8340
      MTOA# 7469
        I have the same problem....I remove the 4 bolts,tension bolt, also the 2 bolts that are on the metal elbow (exit of raw water) ,leaving main ( long section) of raw water hose attached the one from sea strainer then you swing it over between the engines for repair ......Good luck Brad
        Brad & Sharon
        Lady Jake
        Anacortes/La Conner, Wa.
          Dang it...in the fall, I'm going to give a serious look at fabricating some sort of bracket that will raise the seawater pump a couple of inches so we can change our impellers without having to disassemble the whole darned thing! This should be a 15 minute per engine task, rather than a whole day of gruntin', sweatin', and cussin'! :P
          Cheers,
            EH700 raw water pump, impellers, how to change, and tips....
            http://www.baylinerownersclub.org/in...ps-bad-bad-bad
