Is the only access to the washer / dryer through the removal of cabinet in master state room?
58 Bayliner Motor Yacht access to the washer / dryer-gctid818468
"The washer & dryer are stacked on top of each other, opposite at the bottom of the stairs. To access the hoses there is a wardrobe in the 3rd bedroom that you can remove the back & side panels like in the 4788."
Hope it assists. Cheers
John H
Brisbane QLD Aust
"Harbor-nating"
2000 - 4788/Cummins 370's
Did you try the 3rd bedroom closet first and had no luck or you just went straight for the master and creating your own access. Just good to know in case I ever need to.
Have to say many people say a washer dryer is something that never gets used on a boat. We use ours all the time and love the convenience of it.
5788 Man 610's- Love Her !
To go through the 3rd bedroom looked like a lot of work. The bunks are in there pretty tight. The access we did by removing the cabinet and wall covering in the master was an easy spot. We now have an easier way to access if ever needed again.
We also had to remove the hand rail going below. Their is a bolt in the middle that has to be removed. If you take the TV out, there is a panel behind it with 6 screws on it. There is an outlet and a cable connection on the panel so be careful not to pull them apart. You can then get back there and get to the bolt, I believe it is 5/8"
