EH700 Block Coolant Drain-gctid818373
    Got to drain my EH700 coolant. Can't find the block pet cock. I found it before but don't remember anymore. Exhaust manifold is easy to find. It's 90 and humid, my patients is limited here and engine room time is about 15 mins before heat gets you. .
    Block drain is just behind the starter, I believe 14mm wrench. Darin hose is connected to it, I'm able to bring the drain under the starter and put a shallow pan under it, or put a smaller diameter hose into the drain hose and it will drain into a pail.
    James
    Hurth 630's Onan 8kw MDKD
    Lowrance Electronics!
    AGLCA #8340
    MTOA# 7469
        James is spot on...I use a "Suck-up" oil changer to my block drain ...no mess no fuss and dump it at the marina recycle site.
        A cool shower might be in order after your finished ".....Good luck Brad
        Brad & Sharon
        Lady Jake
        Anacortes/La Conner, Wa.
