47 Windless Foot Switch-gctid818347
  • 47 Windless Foot Switch-gctid818347
    What is the quickest way to get a foot switch for a 96 4788 Windless in the NW? Make and part # ? Can switch be changed all above deck?
    Started boating 1965
    BTT Hasn't anyone replaced one???
      You sure the foot switch is bad? Mine were intermittent, but it turned out to be a bad ground of the cable to a bracket in the chain locker.
      Pat
      Paragon
      1999 4788
        Hi Mickey,
        Defender, West marine, Fisheries, etc all carry them. I'm not sure of the part number but you can ID them from the pictures on line.
        Imtra Windlass Foot Switch. Features: Handles full windlass loads without an external solenoid or control box Hinged cover folds flat to the deck when in use When not in use, cover closes to prevent accidental windlass operation Contact a
        They're very easy to repair.
        Just remove it, open it up clean all the parts. (sand off burns or corrosion on the contacts if needed) and put it back together.
        I put dielectric grease in to help keep it from corroding.
        The last one I repaired was underway to Canada while the admiral ran the boat.
        Chris
          We have Mcgivered a temp fix. It clearly was the switch. Contacts really dirty. When reassembled, it worked but needed more pressure than desired. So addition of a couple thin washers fixed it for now. Ià should work until I get a new one installed. Thanks to my son who has better knees than me.
