Oil Pressure Sender Hino 210 Diesel-gctid818020
  • diveguy
    It should look like this. As you have dual stations it would have two wires.
    Guest started a topic Oil Pressure Sender Hino 210 Diesel-gctid818020
    Hi Everybody,
    On the oil filter housing, there appears to be 2 canister type senders. The first has 1 wire, the other is smaller with 2 wires. Can anybody advise which of these might be the oil pressure sender. TIA
