Cummins Oil Pressure Issue-gctid817605
    I had an interesting thing happen a couple of days ago. I was cruising with both engines at 2200 RPM when I noticed the port engine oil pressure fluctuating from 0 to 50 PSI. I quickly ran down to the lower helm and the gauge there was doing the same; then it went to zero and stayed there. There was no alarm from the oil pressure switch when this happened.
    I slowed down and shut down the port engine. I turned the switch back on and verified that the alarm was working; so I restarted the engine. Both oil pressure gauges started operating normally, with no fluctuations and showing adequate oil pressure. They continued to operate OK for the rest of our cruise: three more hours, including a day at anchor with a cold restart.
    I'm guessing the issue is a failing oil pressure sender or bad oil pressure sender electrical connections. Do you have any other thoughts?
    2013 Boston Whaler 130 SS
    Isla Verde, PR
    To be safe I would replace the sender, and perhaps both of them.
    Checking the harness connections is also a possibility for corrosion.
    It won't be far from the engine if both gauges were acting the same way.
    If you order new senders be specific that they are dual station senders to get the correct readings.
    For Faria Guages Sierra OP24891 Oil Pressure Sender-80 Psi,Dual Station
    "Adios Dinero"
    Photo Credit: Whiskywizard
      Well you for sure had oil pressure else the low oil pressure alarm would have went off. As you know it's a separate sender. The senders are a wear item thus need replacing as needed.
      2019 Cobia 240 CC
      2006 Boston Whaler 13 Sport
      1985 3270/Hino 135s (Sold)
      Vero Beach, Fl.
        Does the Oil Pressure Alarms work off the same sender or a different one as the gauge? I'd assume there is only a single oil pressure sender on the engine. So if the alarm didn't trigger but the gauges fell to zero, it's more likely to be a bad/open signal or ground wire given that both gauges were at zero.
        Terry
          Two separate senders. One for the gauge, one for the alarm. They use the same feed from the engines, which is a good thing.
          2019 Cobia 240 CC
          Vero Beach, Fl.
            Exactly, that is why I was comfortable restarting the engine after I verified that the oil pressure switch for the alarm was working.
            I've been wrenching on engines since I was a kid and I've never had an oil pressure sender malfunction and get better all by itself. Usually when they malfunction they stay that way.
            Isla Verde, PR
              I had something like this happen last year and it turned out to be corrosion where the wire connects to the sender. A little sandpaper and corrosionX and it's worked fine.
              "Impasse". 2001 3988
              Cummins 330's
              Puget Sound
              "You don't want to be the richest guy in the nursing home..."
                Swap sensors between engines and see if the problem travels to the other engine.
                Pat
                Paragon
                1999 4788
                  That won't work in this cass because the problem fixed itself. The port engine oil pressure indication is working nirmally now.
                  Isla Verde, PR
                    Good idea. I'll ckean the contacts.
                    Isla Verde, PR
                      Had similar issue on my 6B's, pulled on the sender wire and it came off the terminal. Wire was broken but insulation kept it in place. I re-crimped a new connector on and issue resolved.
