Bow roller-gctid817506
    Need to replace the roller on the pulpit would anyone now if it is 3 inch roller or 5 inch roller ? 3818 pulpit.
    I just replaced mine on my 4550- roller should be the same size as it looks to be the same size as the 3288 roller as well.
    Info in this thread and I posted link of what I bought at bottom of that thread:
      I just did mine on my 3818. https://www.marinedepotdirect.com/an...nt-wheels.html
      You want the 7550U. Add a couple of quarter inch hole fender washers to each side as required to compensate for any spread of the mount.
        Thank you I have ordered the roller, did you replace the bolt also ?
          No, mine is a stainless steel pin with a hole, washer and key ring type keeper at each end.
