Macerator Pump Switch-gctid817473
  • Macerator Pump Switch-gctid817473
    Hello Everyone,
    I need to replace my macerator rocker momentary switches as one of the pins has broken off the back. I am having a hard time finding this part, has anyone sourced these out. They are the little black rocker switches, states they are 10 amps each and have two pins on the back.
    1996 Bayliner 3587
    Twin Cummins 6BT5.9
    A picture of the switch would really help. The switches have varied over the years so the information you provided is great, but doesn't get me there with the appearance part. On my boat, it's a simple push button.
      I have a 1996 3587 with two pumps using the 4 momentary switches to turn them on. All these switches are in the electronics cupboard. I have attached two pictures.
      1996 Bayliner 3587
      Twin Cummins 6BT5.9
        Google "spring loaded carling switch"
        Hope it solves the search
        Joe
        2001 5288
        Lucky Liner ll
          Solved, found Bayliner originals at Great Lake Skipper
          1996 Bayliner 3587
          Twin Cummins 6BT5.9
            I've found replacement rocker switches at RV supply stores.
              It turns out I just worked on a panel like that for a friend. You can eliminate one of the switches if you choose. They are wired in series to make it so you really have to want to operate the pump. The female wire connectors on his were all broken in such a way that it was difficult to see. I replaced the connectors and it was good to go. We were in an area of Canada where pump outs are few and far.
