EH700 Rebuilt Injectors
    $1000 later... all new tips and calibrated to 3130psi
    Can't wait to fire it up
    [img ]http://imgur.com/goQTNC7.jpg[/img]
    They look purdy purdy.
      It was going so well until one of the hold down bolts snapped... then the extractor snapped... :angry: :angry: :angry: :angry: :angry:
      Good news is did get port side done and it purrs like a kitten
        I have the same problem, did you eventually get the bolt out and if so how do you do it?
          Kev,
          Did you use any type of anti seize on the tips when you re installed? If so what did you use?
          Jim Gandee
          1989 3888
          Hino 175's
          Fire Escape
          [email protected]
          Alamitos Bay, SoCal
            I did, just the standard silver stuff. The injector shop recommended I do it.
              Have you tried a counterclockwise drill bit?
              Started boating 1965
                Not yet. Have a few tools coming but will be away from boat for a cpl weeks
                  I'd like to service the injectors in my two EH 700 Hinos non turbo 175 HP. (approx 1500 hrs. TTSN) Rather than pull 12 injectors and send them out and then reinstall the rebuilt injectors a few days later, I'd like to buy a set of 6 reman injectors and put the 6 remans injectors then send in the original 6 for overhaul after which I would repeat the process with the 2nd engine. Does anyone have a supplier who will do this? Does anyone have 6 reman injectos for sale? Ken Jennings 202 378 4868 [email protected]
                  send
                    Hey Kwjennings, did u fix your injectors ? do you have any specs for them ? what is the nozzle number and at what pressure they need to open ?
                    thx, tex
                    1990, 3888 Motoryacht
                    "Disco Volante"
                    Marina Cervar - Croatia
