Looooooooooong story. 4 yrs ago hired experienced marine mechanic to resolve my 1984 Crusader 3.8's loosing coolant in my 32' 3270. Experienced problem after I bought boat and he told me need to remove manifolds, hone the surfaces and install new gaskets etc. In the process did compression test and wound up rebuilding both engines (skipping details.) He did the honing of surfaces and new gaskets and other items required. Well, here we are and am STILL loosing coolant. Not in the oil pan nor in the bilge so has to be going out the exhaust. Had the heat exchangers cleaned and pressure tested. Small leak fixed. Both engines loosing coolant. Stbd engine about twice amount of port engine. Is it possible mechanic installed the "diverters" incorrectly?
Has anyone converted their closed cooling system to raw water? I can't go anywhere this way. After 2 hours stbd engine looses about a quart and port engine about half that. HELP please.
