HURTH OIL CHANGE-gctid816958
    Do you guys suck the oil out of the filler cap or use the drain plug?
    I suck it out of the top with the fluid extractor.
    Dan
    Frostbite Falls, Minnesota
    Claudia V. III
    1988 - 3218
    Gas Drives
      I suck it out through the dip stick tube.
        On my Hurth 630A, the recommended procedure is to remove the oil thru the filter feed. This is how I do mine.
          not all Hurth trannys have a drain plug. My 800's do not. I pump out at the filler and the filter. Don't forget to wash the filter.
          "Adios Dinero"
          Photo Credit: Whiskywizard
            +1
            ________________
            1998 Bayliner 4788
            1989 Bayliner 3270 - SOLD-
